Next »Pages: [1] 2
elm wavetable melody
DAVID Posted: 29 Jun 2018, 03:28 AM
hi i found this http://elm-chan.org/works/mxb/report.html
what it is a wavetable midi player and it is based on the attiny45/85
i got the code working but how do i convert midi files into .asm files??
mit Posted: 29 Jun 2018, 09:07 PM
Ah ELM ChaN, one of my favourites.
In his project he does not use MIDI files at all, just a list of note numbers in a text file. Then there is a perl script to convert this text file to .asm format.
You could potentially write a script to turn MIDI files into the right format though.
DAVID Posted: 29 Jun 2018, 11:47 PM
ok so how can i open the perl file??
DAVID Posted: 29 Jun 2018, 11:55 PM
well it took a while to get it working but with other source code http://www.deep-shadows.com/hax/wordpress/?page_id=1111
unfortunately it uses codevision avr as the compiler (which is not freeware) and requires the attiny85 to run at 27mhz so i need to wait for delivery
mit Posted: 30 Jun 2018, 12:13 AM
Ah, fair enough.
If you are on linux running the perl script is easy, on windows it's probably fairly simple too but you'll have to install it manually.
Did you try out my midi player for attiny85? It only does square waves but at least I made the midi converter in javascript so it runs in a browser and you don't have to install anything.
One of my first AVR projects involved a midi player, it had a simple drum synth too. I never got round to posting it though, I will at some point.
DAVID Posted: 30 Jun 2018, 12:36 AM
yes i have try it out and it is really cool but i wanted to try out wavetable sound, and also that your midi player for the attiny85 have a bit of a problem with the high notes but still really cool and way easier to use
Last edit by DAVID at 30 Jun 2018, 12:38 AM
DAVID Posted: 30 Jun 2018, 12:46 AM
here is the result of the attiny85 wavetable midi player at 16.5 mhz i just
speed it up on audacity
the song is the marble machine song by wintergatan
https://drive.google.com/file/d/1jaPua-c0TcyMKMYs-Tc0-erjKxGBZOU2/view
DAVID Posted: 30 Jun 2018, 01:05 AM
i got lazy at recording the avr output but i got the 4 minutes song to fit
in 8.084 kilobites on the flash memory
mit Posted: 30 Jun 2018, 04:24 PM
Not bad I spose, but having to speed it up (or overclock the attiny to 27MHz) is kinda cheating.
ELM ChaN's works really well, so I decided to adapt my script to convert midi files into his format. The script is here: https://mitxela.com/other/avr/midi2elmchan.htm
I just spent the last two hours going through vgmusic.com and throwing midi files through the converter...
Hmm, I should probably add a way of attaching MP3 files to posts on this forum.
DAVID Posted: 30 Jun 2018, 09:21 PM
thanks a lot i test it out and it is very good
i am sticking with that converter
Last edit by DAVID at 8 Jul 2018, 08:17 AM
DAVID Posted: 30 Jun 2018, 10:10 PM
here is the final result with a low pass filter https://drive.google.com/open?id=1IAidU8Z9OrMWz0vWwplOJSMv-ZWKITyb
song: river follows in you
Last edit by DAVID at 30 Jun 2018, 10:21 PM
DAVID Posted: 25 Jul 2018, 05:04 PM
after a long break i made a video
https://youtu.be/eMpXosbqGGs
mit Posted: 27 Jul 2018, 08:13 PM
Good stuff.
ELM chan's code is really impressive, I still don't know why he only used it for that simple Fur Elise melody.
DAVID Posted: 12 Oct 2018, 08:34 PM
hi, after another break i decided to modify the code so instead of producing a music box tone now it is a square wave.
here is a test https://drive.google.com/open?id=12oOyeX7tPIBNIMUCt05qvno7IdS8aT7e
song starmachine 2000.
i update the code on github https://github.com/theawsomeavr/attiny85-music-box
mossystone Posted: 15 May 2020, 06:43 AM
Registered to say thanks for the converter and to share some images. It let me create a music box with our own melody for my daughter.
Attached is a photo and a screenshot of the layout (diy layout creator.) I haven't found a nice box yet, but I incorporated a header for an off board microswitch to work with the eventual lid.
As an aside, I wonder how elm-chan created his own melody files. I can find nothing on his site in either english or japanese.
I did notice however that he included two melodies in addition to Fur Elise in the zip file you can convert with the included perl script.
At any rate, cheers to all.
Last edit by mossystone at 15 May 2020, 06:48 AM
Next »Pages: [1] 2
