psmears | Posted: 28 Jul 2020, 11:18 AM |
Member Posts: 7 Joined: 28-July 20 |
Hi, Are the designs for the matchbox-like component drawers shown on this page available anywhere? https://mitxela.com/projects/laser_cutter I've searched on the site and couldn't find them, but they'd be really useful! Would be great if you could publish them in some form or other :) Cheers, Patrick ------------- |
[top] | |
mit | Posted: 29 Jul 2020, 01:59 PM |
yeah whatever Admin Posts: 540 Joined: 4-May 16 |
Hi, I can probably dig the design files out, I must have them somewhere. They'll be in moshidraw format though, not sure how useful that's going to be. ------------- |
[top] | |
psmears | Posted: 29 Jul 2020, 03:11 PM |
I can probably dig the design files out, I must have them somewhere. That would be great, thanks! QUOTE (mit)
They'll be in moshidraw format though, not sure how useful that's going to be. That's fine - I'm sure I can come up with some way of converting them to something I can use :) Cheers, Patrick ------------- |
[top] | |
mit | Posted: 31 Jul 2020, 11:05 AM |
OK, found the files, stuck them here: http://mitxela.com/~laserDrawers The drawers2 files are the ones shown in the pictures, that go together without glue. It's a bit of a gimmick, I think the ones I glued together feel less flimsy. The mdr files are readable in notepad, but honestly it might be fastest to just redraw them in inkscape or whatever. ------------- |
[top] | |
psmears | Posted: 31 Jul 2020, 11:51 AM |
That's fantastic, thanks so much :-) ------------- |
[top] | |
psmears | Posted: 5 Apr 2024, 04:15 PM |
OK it's only 4 years later, but I've finally got round to making one of these (I fairly quickly put together a script to convert the files to SVG, then Logistical Reasons meant I wasn't able to actually use the converted files to make anything. But now I have.) I made this with a cutting machine (ie one using a blade rather than a laser), and I think the cardboard I used may be a bit thicker - so the design probably needs a little tweaking to accommodate. But the first attempt is definitely usable! ------------- |
[top] | |
mit | Posted: 6 Apr 2024, 09:56 AM |
Nice! I appreciate the update. I had an idea to 3D print a holder for razor blades, to make an improvised stamp that could just be pressed against card to make more of the drawers. It feels like there must be an easy way to produce a few hundred cutouts of the same design. Then again, if you can get it reliable with the cutting machine maybe that's good enough. The problem with the laser is that I have to stand over it as it runs, since it could catch fire, and also loading the next bit of card is manual whereas a vinyl cutter could load a whole roll. Hmm. ------------- |
[top] | |
psmears | Posted: 29 Apr 2024, 09:01 PM |
I'm afraid the cutting machine isn't all that reliable with card - though it's probably not going to burn the house down! Possibly it could work better with roll media but I'm a cheapskate using cereal boxes so it does require a certain amount of babysitting... (I did successfully use it to make punched paper (actually card) tape for a music box, having written a MIDI-to-SVG converter - before I'd seen your project along the same lines, but very similar, because what else is one going to do with a music box like that - punch all the holes manually, I don't think so! Though apparently a colleague did spend an entire weekend doing so once...) ------------- |
[top] | |
