| anyfoo | Posted: 6 May 2022, 06:15 AM |
Member Posts: 4 Joined: 6-May 22 |
All the project writeups are great, massively so. I spent a lot of time reading them. I have a question about the tiny Theremin project: Why does it have to be floating? I understand that one of the I/O pins has to be either connected to ground or to the player to form the capacitor, but why does the entire circuit floating matter? Heh, now that I type this out... is it because the vicinity of the I/O pins to ground would form a much larger capacitance, drowning out the player? While I'm at it, a comment about one of the synth players where the subject was reusing memory for different algorithms in C, without resorting to unions. Macros and direct addressing were suggested, but I think the simplest solution would just be to declare the data area in the wanted size, such as: uint8_t data[4096]; // must at least be maximum size required by any algorithm And then, have each algorithm have its own structure type, but addressed through a pointer with all pointers simply pointing to your data area: struct alg_foo_t *alg_foo = (struct alg_foo_t*)data; But the union has the benefit that you do not need to figure the size out. So instead of the opaque data area, do this:
And you have the best of both worlds: An automatically sized data area, and easy addressing through a direct pointer to the structure with no union indirection. Last edit by anyfoo at 6 May 2022, 06:21 AM ------------- |
| mit | Posted: 6 May 2022, 09:46 AM |
I can't answer the theremin question. Not only have I forgotten the details, but I didn't really understand how it worked at the time. It was mostly just about experimenting with different arrangements until I found something that works. Good point about the C memory though. I think if I had written it from scratch with sharing memory in mind, I would have gone with something like that. It gets a little uglier because there are arrays of structs, and some structs contain arrays. The channels/polyphonic oscillators looks like this:
Polyphonic algorithm 3 uses the same oscillator struct, because it's nearly all the same, but the fm_whatever floats are used for different purposes. There's also concern about what values are valid, though I suppose when changing algorithm it could wipe them. The monophonic algorithms have their own array elsewhere... but it's only about 20 bytes, so it doesn't really matter, and I like how readable the struct definition is. The prototypes for the algorithms look like this:
