What should be done for applications that may encounter transient overvoltage events higher than the LT4320 absolute maximum rating?
joan0110 Posted: 10 Jan 2022, 08:14 AM
The LT4320 is ideal diode bridge controller that drives four N-channel MOSFETs, supporting voltage rectification from DC to 600Hz typical. What should be done for applications that may encounter transient overvoltage events higher than the LT4320 absolute maximum rating? If you are interested in LT4320, you can click on the following link: [removed]
I would appreciate it if you could help me out.
Best regards!
Joan
Last edit by mit at 10 Jan 2022, 11:36 AM
mit Posted: 10 Jan 2022, 11:36 AM
Is this a genuine question?
Use a TVS diode... like the datasheets suggests... with the exact wording of your question...
