| HollowQwert | Posted: 13 Jun 2018, 11:09 PM |
Member Posts: 19 Joined: 25-May 18 |
After a previous post, I decided to get a USB AVR programmer to program the ATtiny85 microcontroller. However, I ran into another problem, this time with the programmer. I do not know what program to use (I am using a ATmega8 programmer by the way). I didn't know whether to post this on the software, hardware, or the project forum but since it had to do with the Mk II project I decided to put it here, apologies if I should have used one of the other forums. Last edit by HollowQwert at 13 Jun 2018, 11:14 PM ------------- |
| DAVID | Posted: 14 Jun 2018, 02:19 AM |
well to upload i use burn o mat v2 which is a gui interface of avrdude ------------- |
| DAVID | Posted: 14 Jun 2018, 02:20 AM |
is your programmer a usbasp??? Last edit by DAVID at 14 Jun 2018, 11:05 PM ------------- |
| HollowQwert | Posted: 14 Jun 2018, 10:16 AM |
Yes it is a USBasp, and I remember trying to get the burn o mat but when I tried to install it my computer said the file was corrupted or not downloaded property, then again I'm not sure if it was the v2 ------------- |
| DAVID | Posted: 14 Jun 2018, 11:04 PM |
for it to run you also need winavr and java 8 ------------- |
| HollowQwert | Posted: 16 Jun 2018, 03:50 PM |
Do I need to also download a USBasp Driver or can I use the burn o mat without it? ------------- |
| DAVID | Posted: 16 Jun 2018, 04:41 PM |
yes you also need the usbasp driver you can use a tool called zadig or you can install the libusb driver ------------- |
