Recreating FLASH on NUCLEO-L476RG
wtnh Posted: 20 Oct 2019, 06:32 PM
I think the FLASH Synth project is brilliant. While the goal was obviously to create the world's smallest phantom-powered midi synth, I think it would be great to release the code working on the NUCLEO-L476RG development environment for experimenters (like me).
I gather from the project page that the code was developed on a NUCLEO and then ported to the smaller chip.
Since you and H-Pi will be selling finished units, which is great, I was hoping to be able to play around with the much more affordable NUCLEO (geeze - it is only US$14.90 here in the States from Digikey!).
Any chance you could put the NUCLEO version of your code up on Github sometime?
Please :-)
mit Posted: 20 Oct 2019, 06:37 PM
It will be put up eventually, I need to tidy it up a lot first. Also, there is a "nucleo" devboard for the L432KC too, so it will run on that one without needing to modify the linker script.
Priority at the moment though is writing the documentation...
wtnh Posted: 20 Oct 2019, 06:47 PM
Very cool - looking forward to it!
Did not realize there was an L432KC variant - the ST versions are generally confusing.
EDIT - found it - and only US$10.99 - (not as widely stocked as the L476 version). Nice of ST to practically give these things away!
Last edit by wtnh at 20 Oct 2019, 07:08 PM
beamzer Posted: 14 Aug 2020, 06:29 AM
I was thinking of building your Flash STM32 synth inside an old Roland midi keyboard my father left me. He was allways playing with that thing connected to an old PC :). From a hardware point of view, that should be fairly simple of course. While the software is not on github yet, would it be possible to flash the firmware from the h-pi website onto the STM32 devboard and have it work that way? I wouldn't mind buying their UTE as form of support, although microtonality is not a road that i would go.
thanks,
Ewald...
mit Posted: 14 Aug 2020, 11:51 AM
I realize I sound like a stuck record, but I really do mean to put the source code up soon. I was partway through writing a new algorithm before other work got in the way.
I didn't write the UTE software, just advised on it, but I think you'd struggle to use that firmware download on the dev board. The synth won't work without the right lookup tables, which I believe the UTE writes separately. There's also some amount of obfuscation, the idea being to have a clean divide between "official" firmware versions and fan-made modifications when and if the source code is released.
a_q Posted: 14 May 2021, 03:13 PM
Hi! I too have started dabbling with synthesisers and would be interested in running this on a dev board.
- Adam
mit Posted: 14 May 2021, 05:10 PM
Maybe soon!
