| GiovanniPio | Posted: 31 May 2018, 02:10 PM |
Member Posts: 2 Joined: 31-May 18 |
Hey, people, I really need some help: I flashed my HC-05 module with RN-42 firmware, then i tried to hook it up as shown in the video linked below, but instead of using an arduino nano I'm using the uno. The problem is that RN-42 commands don't work in the serial monitor... In the hookup everything seems to work fine, the led blinks once per second, the code uploads succesfully, but then i write $$$ and press enter (or click send) and nothing happens. Link to the video: https://www.youtube.com/watch?v=UJaqHnPR-XE&t=157s Here's the code:
| GiovanniPio | Posted: 31 May 2018, 02:22 PM |
I did some tests, turns out that the code blocks in this part of the loop function:
in order to show where there was a problem I wrote an else to this piece of code, like this:
So, now that I know this, how do i solve it? Can you help me to find the problem? ------------- |
| DAVID | Posted: 31 May 2018, 09:20 PM |
or you can pop out the atmega328p from the socket and connect the rx pin of the hc05 to the tx of the arduino ------------- |
| DAVID | Posted: 31 May 2018, 09:21 PM |
or use the ftdi cable ------------- |
| DAVID | Posted: 31 May 2018, 09:30 PM |
and i test your code and it work fine for me with the software serial port running at 115200 baud but without the hc05 pullup on pio 7 Last edit by DAVID at 31 May 2018, 09:31 PM ------------- |
| DAVID | Posted: 16 Jul 2018, 02:46 PM |
did you check that the hc05 has power at the 3.3v regulator?? ------------- |
