| stig | Posted: 3 Jun 2025, 04:04 PM |
Member Posts: 1 Joined: 3-June 25 |
Hi - Here from mr. Geerling video - and pretty impressed by your clock. If you are up for ideas for the next version here is a few: 1) add a 433mhz transiver: gives you the possibilities to add "slave" clocks with the same precision but without the need for satellite module. Same precision can achieved by doing a ping/pong style of timing on the slave to measure the time taken. Would also allows others to make gadgets take advantage of the time without implementing a full blown network stack. And perhaps the slave clocks could be made cheaper. 2) Add some sort of ethernet connection: make a NTP and PTP server. If the connection would be wired, then clock could be powered with POE ------------- |
| mit | Posted: 3 Jun 2025, 10:59 PM |
Some kind of slave system might be worthwhile, I'm not sure if 433MHz would be the way to go given how unreliable and noisy it is, you'd have to write your own protocol and make it immune to interference. I experimented with making a wifi NTP device, this was quite a few years ago using an ESP8266. I wanted to see if I could get sub-millisecond accuracy despite the wifi. I ought to publish that at some point. I think I got it to discipline the oscillator of the ESP chip and managed to make it mostly stay within a millisecond or two. A big problem is that most of the NTP pool is not as accurate as it claims to be, some of the supposedly stratum-1 servers were off by half a second. I remember the cloudflare servers were pretty good and made it only poll them. I agree that a PoE precision clock would be pretty neat. ------------- |
| Catsmith | Posted: 6 Jun 2025, 05:12 PM |
¯\_(ツ)_/¯ Member Posts: 2 Joined: 6-June 25 |
From what I can tell it seems like the mark IV uses a micro-usb port, (based on pictures and videos ive seen) And I personally would have preferred it to be Usb-c but just like the fact that the version III that i have is 24 hour Instead of 12 hour, the fact its micro USB is insignificant enough for me to not be dissuaded (spelling? idk) from purchasing a mark IV (when possible), i only noticed that it was 24 hour after receiving my mark III ------------- |
| robohack | Posted: 26 Jul 2025, 09:44 PM |
Member Posts: 1 Joined: 26-July 25 |
I strongly second the request for an ethernet (POE for power too!) port, running an NTP server. I suspect this might require another micro-controller, though on the other hand maybe the date processor has lots of compute power left over to run a TCP/IP stack and an NTP server? PTP would be a bonus too! ------------- |
| mit | Posted: 3 Aug 2025, 10:49 AM |
To be clear, just running the clock from PoE is easy, there are cheap PoE adapters that provide USB power. We could tack on a basic NTP server easily enough, but to make a good time server is a lot of work. There are all kinds of subtle problems, such as how to behave when GPS signal is lost. The timepulse of the onboard GPS module is accurate to about 50ns, which is four orders of magnitude better than our millisecond display, but if we're looking at a PTP server then there are better GPS modules available (ones that need the antenna to be in a fixed location). Overall a PoE Precision Clock that's a network time server is a cool idea, but quite a different project to what the current Precision Clock is. Practically speaking, something like the time-pi is a better bet - or maybe we should just chuck a raspberry pi and the precision clock together in a box. ------------- |
| Phil4 | Posted: 24 Oct 2026, 06:57 PM |
Member Posts: 1 Joined: 24-October 26 |
One suggestion for the Mk V would be optional Wi-Fi NTP synchronisation. The main benefit would be flexibility in positioning the clock. The Mk IV’s external GPS antenna is a big improvement, but getting a good signal indoors can still mean running a cable to a window. Wi-Fi NTP could provide an alternative where GPS reception is difficult, while retaining GPS for maximum precision. Configuration could simply be through config.txt, as with many of the existing options, avoiding the need for an app or additional controls. I don’t think it needs to act as an NTP server, just a client. That would solve the positioning problem without adding too much complexity. ------------- |
| mit | Posted: 24 Oct 2026, 09:11 PM |
QUOTE (Phil4)
I did spend a while developing exactly that for the Mk3 clock. There is a partial writeup about it here: wifi timeOne suggestion for the Mk V would be optional Wi-Fi NTP synchronisation. But the timing accuracy over wifi is nowhere near good enough for a millisecond display. I decided that having an SMA connector for the antenna, and a potentially long cable, was a much better solution. ------------- |
