Precision clock - half digits turn on
breadstock Posted: 29 Jun 2022, 07:45 PM
I'm very new to electronics and can't find where I've gone wrong.
Only the digits before the GMT/BST are lighting up and the GPS module LED lights up but not the GMT LEDs. Which bits should I be looking at to find the problem?
Last edit by breadstock at 29 Jun 2022, 08:11 PM
mit Posted: 30 Jun 2022, 11:27 AM
This is most likely a soldering problem on the display driver chip for the side that isn't working. It can probably be fixed by re-soldering the legs of the MAX7219 chip from the component side.
I would first look closely to see if any of the joints have obvious problems - feel free to share a closeup picture and I might be able to spot something. The most likely pins to have problems would be LD_TIME or SPI_DATA:
or here:
I've put an online interactive schematic here: https://mitxela.com/~clock3bom which can be useful for tracing out connections. If you have a multimeter, you can use it in continuity mode to check there is continuity between the display chip's pins and the ATtiny.
