PNG Sequenz
antonkr Posted: 25 Aug 2023, 08:28 PM
I'm new to plotting but want to experiment with animation and 3D software combined with drawing with the plotter.
I discovered the amazing Tool Plotterfun and it has a function that is very helpful for me except that I can't load in image sequences. Do you know how that would be possible or is there any other way I can archive that?
mit Posted: 29 Aug 2023, 11:02 AM
The simplest option is to load each image manually. You may be able to produce an AutoHotkey script to do that.
Alternatively if you're competent with javascript you could modify plotterfun to accept a sequence.
Linedraw was ported from a python script, so if that's the algorithm you wanted to use, you could make a script to process a lot of images quite quickly, just invoking it from the command line.
