Plotter problem linedraw
antonkr Posted: 2 Sep 2023, 03:53 PM
Hello
I have managed to create an svg sequence but
my plotter keeps hanging up on the line drawings and at a certain point only draws abstract lines. Opening the SVG in another program and exporting it again doesn't help either, is there something wrong with the algorithm?
mit Posted: 4 Sep 2023, 12:23 PM
If the SVG looks fine when you open it, then it's a problem with your plotter, not linedraw. What plotter are you using, does it take SVG directly?
It might be that the design is too complex for it, if so you might be able to simplify it, either in inkscape or by changing the settings for linedraw.
