| rol_cc | Posted: 31 Jul 2019, 03:23 AM |
Member Posts: 1 Joined: 31-July 19 |
Hi! I have a Hamamatsu PMT and photon counter. I saw your experiment with sugar, did you get any cool other suggestions for how to use your PMT? ------------- |
| mit | Posted: 31 Jul 2019, 05:54 PM |
Sticky tape gives off light as you unroll it which should be detectable. But the best thing to do is get hold of some kind of scintillator and build a sensitive radiation detector. If you have multiple scintillation detectors you can stack them and look for coincidence caused by cosmic rays. If you have enough of them, you could build a gamma camera! ------------- |
| nithinjackson | Posted: 14 Nov 2019, 05:41 AM |
Member Posts: 1 Joined: 14-November 19 |
I planned to work with a PMT that can be used as chemiluminometer.. Please help me about how can I connect it with a data analyzing board? What kind of output will be coming out of it? how can i count the photons? ------------- |
| mit | Posted: 14 Nov 2019, 01:59 PM |
Which PMT are you using? Do you have a power supply for it? Is there some readout hardware you have or are you just getting an analog signal? ------------- |
