MIDI on the ATtiny85 for Korg Monotron
Lowebrau Posted: 31 Jan 2019, 10:13 PM
Hello,
I'm undertaking the MIDI for Korg Monotron project.
As I'm waiting for the parts to come in the mail, I was reading the pages on this project.
I'm wondering if all the code that needs to be put on the ATtiny85 is what's on the project page:
ldi r16, (1<<PLLE|1<<PCKE)
out PLLCSR,r16
ldi r16, (1<<PWM1A|1<<COM1A1|1<<CS10)
out TCCR1,r16
ldi r16, (1<<PWM1B|1<<COM1B1)
out GTCCR,r16
ldi r16,255
out OCR1C,r16
It wasn't entirely clear to me
Thanks!
mit Posted: 1 Feb 2019, 10:21 PM
Hi, there's more to it than that. The full source code is on github: https://github.com/mitxela/MidiMonotron
I forgot to link to that on the project page (I will update that when I next get a chance)
Good Luck!
Lowebrau Posted: 9 Feb 2019, 08:24 PM
Ok, thank you for that!
Carlos_Luna Posted: 16 Mar 2020, 08:37 PM
Hi there, thanks for sharing your project info. Do you know if I can do the same for a Monotron Delay? I didn't find the "LFO reset" in the schematic. It should be a way, just wondering.
Thanks for the great work!
Greetings from Mexico
mit Posted: 17 Mar 2020, 12:01 AM
I don't own a monotron delay but it should work.
It took a fair bit of experimenting to find the LFO reset on the monotron, it's not clearly labelled like the other signals, but it is labelled on the (non-delay) schematic right in the middle.
epsteinbarr Posted: 9 Nov 2020, 11:52 AM
Hello,
I'm trying to do that on an Attiny2313 (programming it with an arduino UNO board), but i can't figure how to adapt your project to it. There are some hints, or links that can help me? Thanks in advance
mit Posted: 9 Nov 2020, 04:13 PM
The ATtiny2313 is quite a different chip, so you'll basically have to start over from scratch. It has a hardware UART, so that makes things easier (most of the ATtiny85 code is about bitbanging the uart decode). The timers are a lot less flexible so I'm not sure if you'll be able to generate the voltages correctly.
E18 Posted: 18 Dec 2021, 01:04 AM
This is very nice work! Can you please elaborate how you dealt with the issue of the gate voltage effecting the pitch? I didn't see a gate output in the schematic.
I've been exploring the circuit mods from:
http://www.dinsync.info/2010/06/how-to-modify-korg-monotron.html
and
https://www.youtube.com/watch?v=iT__-bH8Q0o
(circuit)https://github.com/matthewcieplak/monotron-cv-adapter
How does your circuit overcome the problem of the calibration of Volts/Octave and stability of pitch over time?
Both of these other pure-CV mods seem to struggle with both the gate and tuning the Volts/Octave.
Thanks.
mit Posted: 18 Dec 2021, 01:36 AM
The gate signal is connected to PB3 of the ATtiny chip. The gate voltage is held steady for the duration of the note, so it doesn't matter that it affects the pitch.
I do remember the pitch scale drifting over time, I changed the trimpot out with a small multi-turn one, mounted it next to the TRS socket and made a hole in the case so it can be adjusted with a screwdriver without having to open it up. This was pretty effective, just means you have to adjust it every now and then.
