Laser Cutter SVGs
braeden-young Posted: 19 Feb 2021, 02:47 AM
Fantastic work on the music box, did you post your SVG for the servo mounts anywhere?
mit Posted: 19 Feb 2021, 11:51 AM
I don't think I even saved the files at the time.
It's just a bunch of rectangles, the pitch of the tines is 2mm so each rectangle was shifted down by some amount and across by 2mm.
Make sure to allow space for the servo's cable, too. If the rectangle is the exact size of the servo, you won't be able to mount it because the cable gets in the way.
braeden-young Posted: 19 Feb 2021, 07:42 PM
Ah gotcha. Thanks for the reply
