| helectro | Posted: 9 Apr 2022, 11:31 PM |
aucun titre Member Posts: 5 Joined: 9-April 22 |
Hello kind people! I recently saw the encoder repair / replacement project on this site, and it impressed me as an owner of a JV-2080 with a jumpy encoder. After some reflection, I decided to try this solution for my JV-2080. I have created PCBA design in KiCAD that, and I very much don't mean to be rude by saying this, improves upon what is presented on the original project page. Before I finalize the design and purchase the raw boards, I am wondering if mit could tell me what specific encoder they used? I would prefer to use the same one since it worked so well in the application presented on the site. Attached, you will find a screenshot of the PCBA design. My design currently uses a Bourns PEC11R series part as a placeholder, as it is pretty common. I plan to host the design on my github shortly. Perhaps the design could help others with encoders that have lost their precision. ![]() Thanks for letting me know! ------------- |
| mit | Posted: 10 Apr 2022, 05:50 PM |
Hello! Unfortunately I cannot tell you the part number for the encoder I used, it was a generic one I had in my drawer, which I bought in bulk a long time ago. But they're just mechanical devices, so there shouldn't be much difference in it. I guess just check you get approximately the right number of detents per revolution. ------------- |
| helectro | Posted: 10 Apr 2022, 09:24 PM |
Thanks for the quick reply! Understood about the encoder - I think you are right in the end. I will post in this thread again once I've put everything together. In case anyone is interested, the KiCAD design can be found here: https://github.com/HomoElectromagneticus/jv-2080-enc. I will update the repo with any changes going forward. ------------- |
| helectro | Posted: 25 May 2022, 02:41 AM |
Hello again! I have recieved the PCBs from my supplier and am now trying to flash the ATTiny13A with the source code from github. However, when running make at the root directory, I get the following linker error: avr-gcc -mmcu=attiny13a -Wall -Os -g -o sc.bin sc.c Which is unexpected, considering both `incr` and `decr` are defined in the source code already. I wonder if avr-gcc is actually failing in the definitions of those functions... Anyway I would love either some help debugging my toolchain (maybe there is something wrong with my PATH variable?) or just a pre-compiled binary / hex I could load on the ATTiny13A with avrdude. Thanks in advance and take care! ------------- |
| mit | Posted: 25 May 2022, 08:59 AM |
I'm not sure what's happening there. What version of avr-gcc are you using? Do other c programs compile OK? I just cloned the repo and compiled it myself, the hex file is here: https://raw.githubusercontent.com/mitxela/jv1080-encoder/master/sc.hex Haven't tested it. ------------- |
| helectro | Posted: 25 May 2022, 08:41 PM |
I'm not sure what's happening there. What version of avr-gcc are you using? Do other c programs compile OK? Thanks for your quick reply! I am using avr-gcc 9.3.0. I am able to compile the following simple "blink an LED" program: #ifndef F_CPU Then compiling it works fine: ryan ~/sw/avr-test% avr-gcc -mmcu=attiny13a -Wall -Os -g -o led.bin led.c So I am not sure what about your code my toolchain doesn't like... What version of avr-gcc did you use to compile this? QUOTE (mit)
I just cloned the repo and compiled it myself, the hex file is here: https://raw.githubusercontent.com/mitxela/jv1080-encoder/master/sc.hex Haven't tested it. This is excellent, thank you! I was able to flash the code onto my ATtiny13A via an Arduino UNO as ISP with the following avrdude command: avrdude -P /dev/tty.usbmodem14201 -c avrisp -b19200 -p t13a -v -v -U flash:w:sc.hex:i -B50 However, the pulses I am seeing come out of the ATtiny13A are only ~130us wide instead of ~1ms. This makes me think the clock frequency is set too high. I am looking into how to set the fuses now. I am used to other microcontroller species where you can define this stuff in software! ------------- |
| helectro | Posted: 26 May 2022, 01:39 AM |
My problem was indeed with the fuses. Once I programmed the ATtiny13A with the following avrdude command, everything worked as expected:avrdude -P /dev/tty.usbmodem14201 -c avrisp -b19200 -p t13a -U hfuse:w:0xFF:m -U lfuse:w:0x73:m -U flash:w:sc.hex:i -B50 It's worth noting that the ATtiny13A does not have an extended fuse byte, so the comment at the top of the source code // Fuses (E:FF, H:FF, L:73) - 128kHz as cpu clock is a bit misleading. I only discovered this after trying to pass "-U efuse:w:0xFF:m" to avrdude when programming the micro. Specifically, this is the error avrdude sends when trying to burn the extended fuse byte: "efuse" memory type not defined for part "ATtiny13A" This can be verified with the micro's datasheet as well of course. Anyway now my JV-2080 has a working encoder, which is pretty cool! Thanks mit for your assistance and prior work! I will play around with avr-gcc to figure out why your code does not compile on my computer. I also have a small revision of my PCB to do in case some person in the future wants to build one. ------------- |
| mit | Posted: 29 May 2022, 09:19 AM |
Well done on getting it working. Yes, there's no efuse, apologies. I think I just pasted the three fuse values from the verification that avrdude does, which reads out FF for efuse regardless. By the way, you can tell avrdude to read and write individual fuses, you don't need to write the hex file at the same time. Rather than datasheets I usually use an online calculator for it like this one. You can just check things on and off and then copy the value or avrdude command. Saves a lot of headache around the terminology (like "unprogrammed" being 1, and "programmed" being 0, etc). ------------- |
