| DAVID | Posted: 29 Sep 2018, 03:21 AM |
after watching your post https://mitxela.com/projects/turtle i wanted to make it, did you use the code of your attiny85 greetings card or was it the code of ELM chan´s wavetable music box (and the comverter that you desing on my post about the wavetable music box) ------------- |
| mit | Posted: 29 Sep 2018, 11:51 AM |
Yeah it was the ELM ChaN code using the converter I wrote. But I guess either of them would work, because I think they both output to the same pins. The battery is wired up via the front two legs, this didn't work as well as it could have done because some metal surfaces are not conductive enough. It would be better to put the ATtiny to sleep, and just sense whether the legs are connected, and use that to wake up the chip. ------------- |
