| hiv0ltage | Posted: 2 Dec 2023, 07:12 AM |
Member Posts: 2 Joined: 2-December 23 |
I have been looking for a proper sensor to detect heart rate for a horse. They have ones that you can buy but they are terrible for the application I need them for. I figured that a horse has a large neck and the sensor can be placed there and attached using a neck sweat (the ones that are wrapped around the horses neck and look like a scarf). The issue is the fur. in humans our skin is easily accessible but on horses its not. I do not want to shave my horse just to add a sensor there. I also need the senor to be safe and not irritate. Horses are prone to rub and could either damage the sensor or its skin. The breath rate is similar and can be added to the throat area where the heart rate sensor is. The goal is to monitor the horse even if its lying down. The expensive ones goes on the legs and can be easily knocked off or shifted plus they don't measure the horses breathing. Once I can get a decent sensors I am pretty cleaver about the code. Any ideas welcome. And yes I own a horse. ;) ------------- |
| mit | Posted: 4 Dec 2023, 01:51 PM |
This has to be one of the most unusual requests posted here. As far as I know, the sensors on smart watches are actually quite bad at what they do, most of them are very inaccurate, and usually sampled too infrequently for anything but casual interpretation. I have seen some interesting projects that use a webcam to monitor heartrate by applying DSP autocorrelation techniques to the video footage. It sounds implausible, but it apparently works. But it depends on the extremely subtle variations in skin tone, which would again be hidden under the fur on a horse. There is something appealing about simply having a camera in the stable and using computers to extract heartrate and breath info from the footage. ------------- |
| fogh1 | Posted: 9 Dec 2023, 04:20 AM |
Member Posts: 7 Joined: 9-August 22 |
Might just be able to strap an accelerometer in a strategic location and find the periodic signal from the heart beating. I like to think that my Apple Watch is at least decent at heart rate detection. Breathing rate probably not. ------------- |
| hiv0ltage | Posted: 9 Dec 2023, 11:31 PM |
I know it is unusual but I was hopeing to find something that would work. Even if its not perfect. Just has to be able to detect if the horse is agitated or not. Using a video would require a lot of signal processing and that is beyond my capability atm. ------------- |
| mit | Posted: 24 Dec 2023, 10:01 PM |
Forwarding the following message: QUOTE
