| dcameron | Posted: 6 May 2018, 01:20 PM |
Member Posts: 2 Joined: 6-May 18 |
In https://mitxela.com/projects/stylocard you mentioned that you made that PCB with your 'usual process at the time' https://mitxela.com/projects/etching_pcbs If that was your process then, what are you doing now? ------------- |
| mit | Posted: 7 May 2018, 12:16 AM |
Good question. Basically, once I found out how cheap you can get PCBs from China I stopped etching them at home. The only reason to etch them yourself is if you need them really quickly. The boards I ordered from China the other day arrived just over a week later, and they're much higher quality than anything I could make at home. The only interesting circuit board etching I've done since then is making the charliestar project which involved etching a flexible PCB, but the process was pretty much the same. ------------- |
| robonson | Posted: 26 Jul 2018, 09:57 PM |
Member Posts: 1 Joined: 26-July 18 |
To make the PCB, you have to do some steps and the steps are as follows. First desiogn and then cut it. Next print the inner layer, after that remove the unwanted layer and then do the optical inspection. Hope this will help you and I got to know this from Last edit by mit at 27 Jul 2018, 08:04 PM ------------- |
