attiny85 playtune library
DAVID Posted: 10 Sep 2018, 05:44 AM
hi, for a looooong time i wanted to adapt the playtune library https://www.youtube.com/watch?v=zJbhy0ghSWE&t=226s https://github.com/LenShustek/arduino-playtune.
i notice that LenShustek had also modified the library to get it working in the attiny4313 https://github.com/LenShustek/ATtiny-playtune/, but since of the limitations of the attiny4313 with only 4k
of flash memory (and only able to use 2k for music since the sketch needs the other 2k) i wanted to modified again so that it will work on the attiny85 and finally i got it working.
you can check it out over here:https://github.com/theawsomeavr/Attiny85_Playtune_master
my video about it:https://youtu.be/vnaZM2b0MEA
Last edit by DAVID at 10 Sep 2018, 05:47 AM
mit Posted: 10 Sep 2018, 11:15 AM
Nice work.
I like that it's battery powered, how do you charge the battery though?
It would be cool if you could get it to load songs from an SD card or something.
DAVID Posted: 10 Sep 2018, 09:17 PM
for charging the battery i need it to remove it and use a tp4056 charger.
and for the micro sd card it will be cool but i can also upgrade to the smd
version of the atmega328, i choose the attiny85 since it is easier to program it compared to the smd atmega328.
