| DAVID | Posted: 28 Oct 2018, 08:13 PM |
I love mcus Member Posts: 237 Joined: 10-September 17 |
hi, since past year i was doing a mist maker with arduino/atmega328 but i was not able to create the required 140 khz, how can i create one? ------------- |
| [top] | |
| mit | Posted: 29 Oct 2018, 05:44 PM |
yeah whatever Admin Posts: 704 Joined: 4-May 16 |
140kHz should not be too hard to produce. You could probably do it with delay routines and toggling pins, but the proper way to do it is with one of the hardware timers. Page 99 of the atmega328p datasheet says this about timer 0: ![]() It takes a bit of poking around with the registers to configure it right, but with this there should be no problem generating any frequency up to 8Mhz. ------------- |
| [top] | |
