ne722 gateway fixing
DAVID Posted: 8 Jan 2018, 08:15 AM
hi i have using a ne722 gateway laptop for 2 years and still is working
fine, the problem is that i plug in to a usb port a shitty chinese iphone
and then my computer yust turn off, i rebooted and when i plug a usb device
in to the that usb port it didn´t recognize it.
so why does it happened and should i buy a new usb host controller??
mit Posted: 23 Jan 2018, 10:26 PM
This type of problem is much easier to debug if you are running linux. You can look at the kernel messages by running dmesg and see what errors come up as you plug and unplug the device. On windows, I am not sure how you go about investigating this, but it does sound like something is broken.
Are there other USB ports still working? There are usually internal hubs on most things and maybe only some of the USB hardware is damaged. Also, if there's a PCI slot, or PCIMCIA, or expresscard, you could consider adding new USB ports with an adapter.
DAVID Posted: 28 Jan 2018, 03:49 AM
well it only works a 3.0 usb port
DAVID Posted: 28 Jan 2018, 03:50 AM
and there isn´t any other expansion slot
everything is solder direcly into the motherboard
only the ram and hard drive aren´t solder
Last edit by DAVID at 28 Jan 2018, 03:51 AM
jackvocks12 Posted: 7 Sep 2018, 08:46 PM
I can easily solve the gateway error. it mainly occur due to Internet connection which is really good for us. That's why I am use the router. if I have any issue with that go to the Linksys tech support which provide the best support which is really good to me. I can also contact them to solve any issue.
Last edit by mit at 9 Sep 2018, 07:32 PM
DAVID Posted: 7 Sep 2018, 09:42 PM
crap why there is so much spam in this forum recently
