| DAVID | Posted: 3 Aug 2020, 05:12 AM |
I'm currently trying to make a new usb midi synth with the stm32 (bluepill) and so far it's been going pretty nicely until I began implementing pitch bend capabilities. The way that I´m doing it is by the use of the pow function.
As you migth expect it works but it is way too intense for the CPU. As far as I understand from your Flash Synth post I need to have a lookup table of the pitch bend factors from -1 to +1 semitone but then how do I scale those values for other semitone ranges? ------------- |
| mit | Posted: 3 Aug 2020, 02:09 PM |
yeah whatever Admin Posts: 684 Joined: 4-May 16 |
There's a few ways you can go about this. If you have a pitch bend lookup table for one semitone, you can just multiply it several times to get a bigger bend range. So if the pitch wheel was at +100%, the table would say the bend factor is 2**(1/12) = 1.0594630943592953. If the bend range is 4, you would multiply the frequency by 1.059... four times. However for big bend ranges that way is slow and prone to floating point errors, especially if the values are float32 instead of double floats. The way I do it on the Flash Synth is to use two lookup tables. One has 128 values, and tells me the base frequency of the midi note, using equal temperament. The other table is the +/- one semitone table. To work out the frequency, I split the bend amount into two parts, the whole number of semitones, and the fraction. I then add the whole number onto the midi note number, then use the other table to adjust by the fraction amount. This gives 14-bit resolution bends with any bend range, and just two lookup tables. One problem is that the Flash Synth supports alternate tunings, so this way won't work if the distance between midi notes is not constant. For the tuning table modes, I just forced the bend range to a fixed amount, because I'm not sure it even makes sense otherwise. I will upload the code for the flash synth soon, I promise... ------------- |
| DAVID | Posted: 3 Aug 2020, 09:13 PM |
Thanks Mit, it now works flawlessly and I have also increased the pitch bend res from 7 bits to 11 and the difference between those when having a really big pitchbend range (96 in my case) it´s humongous.
Last edit by DAVID at 3 Aug 2020, 09:13 PM ------------- |
