DAVID | Posted: 28 Jan 2018, 03:53 AM |
hi i try to make a ps2 keyboard with an avr but is this possible and how? ------------- |
[top] | |
mit | Posted: 4 Feb 2018, 10:51 PM |
yeah whatever Admin Posts: 564 Joined: 4-May 16 |
Never tried it but I think ps2 keyboards are just using SPI. If you choose an AVR chip that has a hardware SPI port, it should be quite easy. ------------- |
[top] | |
DAVID | Posted: 5 Feb 2018, 01:55 AM |
i am planning to use an attiny85 ------------- |
[top] | |
mit | Posted: 7 Feb 2018, 09:58 PM |
It's possible to do SPI on an attiny85 but it's not as straight forward. It has something called a universal serial interface (USI) which takes a bit more effort to get working, you might have to look up some tutorials on it. Or you could chose a chip which has an SPI port. ------------- |
[top] | |
DAVID | Posted: 9 Feb 2018, 04:41 AM |
i will switch to the atmega328 ------------- |
[top] | |
DAVID | Posted: 10 Feb 2018, 09:05 AM |
hey mit, i get it working with the attiny85, it is really simple to use it because those are just interrupts code: http://codeandlife.com/2013/06/28/minimal-ps2-keyboard-on-attiny2313/ i just tweak it a little bit ------------- |
[top] | |
DAVID | Posted: 10 Feb 2018, 09:06 AM |
#include <avr/io.h> #define F_CPU 16000000UL #include <util/delay.h> #define PS2_CLOCK_DDR DDRB #define PS2_CLOCK_PORT PORTB #define PS2_CLOCK_PIN 0 #define PS2_CLOCK_INPUT PINB #define PS2_DATA_DDR DDRB #define PS2_DATA_PORT PORTB #define PS2_DATA_PIN 1 #define PS2_DATA_INPUT PINB static void clockHigh(void) { PS2_CLOCK_DDR &= ~_BV(PS2_CLOCK_PIN); // set as input PS2_CLOCK_PORT |= _BV(PS2_CLOCK_PIN); // set pullup } static void clockLow(void) { PS2_CLOCK_PORT &= ~_BV(PS2_CLOCK_PIN); // zero output value PS2_CLOCK_DDR |= _BV(PS2_CLOCK_PIN); // set as output } static void dataHigh(void) { PS2_DATA_DDR &= ~_BV(PS2_DATA_PIN); // set as input PS2_DATA_PORT |= _BV(PS2_DATA_PIN); // set pullup } static void dataLow(void) { PS2_DATA_PORT &= ~_BV(PS2_DATA_PIN); // zero output value PS2_DATA_DDR |= _BV(PS2_DATA_PIN); // set as output } #define readClockPin() (PS2_CLOCK_INPUT & (1 << PS2_CLOCK_PIN)) #define readDataPin() (PS2_DATA_INPUT & (1 << PS2_DATA_PIN)) #define CLK_FULL 40 #define CLK_HALF 20 void ps2init() { clockHigh(); dataHigh(); } int ps2write(unsigned char data) { unsigned char i; unsigned char parity = 0; if(!readClockPin() || !readDataPin()) return -1; // clock or data low dataLow(); _delay_us(CLK_HALF); // device sends on falling clock clockLow(); // start bit _delay_us(CLK_FULL); clockHigh(); _delay_us(CLK_HALF); for(i=0; i<8; i++) { if(data & 1) { dataHigh(); parity++; } else dataLow(); _delay_us(CLK_HALF); clockLow(); _delay_us(CLK_FULL); clockHigh(); _delay_us(CLK_HALF); data = data >> 1; } if(parity & 1) dataLow(); else dataHigh(); _delay_us(CLK_HALF); clockLow(); _delay_us(CLK_FULL); clockHigh(); _delay_us(CLK_HALF); // stop bit dataHigh(); _delay_us(CLK_HALF); clockLow(); _delay_us(CLK_FULL); clockHigh(); _delay_us(CLK_HALF); _delay_us(50); return 0; } #define BUTTON_DDR DDRB #define BUTTON_PORT PORTB #define BUTTON_PIN 2 #define BUTTON_INPUT PINB int main() { ps2init(); BUTTON_PORT |= _BV(BUTTON_PIN); // pullup on button while(1) { if(!(BUTTON_INPUT & _BV(BUTTON_PIN))) { ps2write(0x29); _delay_ms(50); ps2write(0xF0); _delay_ms(10); ps2write(0x29); _delay_ms(200); } } return 1; } ------------- |
[top] | |
DAVID | Posted: 10 Feb 2018, 10:52 AM |
and here is a table of keys BTKC_NONE, //0x00 (0) BTKC_F9, //0x01 (1) BTKC_NONE, //0x02 (2) BTKC_F5, //0x03 (3) BTKC_F3, //0x04 (4) BTKC_F1, //0x05 (5) BTKC_F2, //0x06 (6) BTKC_F12, //0x07 (7) BTKC_NONE, //0x08 (8) BTKC_F10, //0x09 (9) BTKC_F8, //0x0A (10) BTKC_F6, //0x0B (11) BTKC_F4, //0x0C (12) BTKC_TAB, //0x0D (13) BTKC_GRAVE, //0x0E (14) BTKC_NONE, //0x0f (15) BTKC_NONE, //0x10 (16) BTKC_ALT_LEFT, //0x11 (17) BTKC_SHIFT_LEFT, //0x12 (18) BTKC_NONE, //0x13 (19) BTKC_CTRL_LEFT, //0x14 (20) BTKC_Q, //0x15 (21) BTKC_1, //0x16 (22) BTKC_NONE, //0x17 (23) BTKC_NONE, //0x18 (24) BTKC_NONE, //0x19 (25) BTKC_Z, //0x1A (26) BTKC_S, //0x1B (27) BTKC_A, //0x1C (28) BTKC_W, //0x1D (29) BTKC_2, //0x1E (30) BTKC_NONE, //0x1f (31) BTKC_NONE, //0x20 (32) BTKC_C, //0x21 (33) BTKC_X, //0x22 (34) BTKC_D, //0x23 (35) BTKC_E, //0x24 (36) BTKC_4, //0x25 (37) BTKC_3, //0x26 (38) BTKC_NONE, //0x27 (39) BTKC_NONE, //0x28 (40) BTKC_SPACE, //0x29 (41) BTKC_V, //0x2A (42) BTKC_F, //0x2B (43) BTKC_T, //0x2C (44) BTKC_R, //0x2D (45) BTKC_5, //0x2E (46) BTKC_NONE, //0x2f (47) BTKC_NONE, //0x30 (48) BTKC_N, //0x31 (49) BTKC_B, //0x32 (50) BTKC_H, //0x33 (51) BTKC_G, //0x34 (52) BTKC_Y, //0x35 (53) BTKC_6, //0x36 (54) BTKC_NONE, //0x37 (55) BTKC_NONE, //0x38 (56) BTKC_NONE, //0x39 (57) BTKC_M, //0x3A (58) BTKC_J, //0x3B (59) BTKC_U, //0x3C (60) BTKC_7, //0x3D (61) BTKC_8, //0x3E (62) BTKC_NONE, //0x3f (63) BTKC_NONE, //0x40 (64) BTKC_COMMA, //0x41 (65) BTKC_K, //0x42 (66) BTKC_I, //0x43 (67) BTKC_O, //0x44 (68) BTKC_0, //0x45 (69) BTKC_9, //0x46 (70) BTKC_NONE, //0x47 (71) BTKC_NONE, //0x48 (72) BTKC_PERIOD, //0x49 (73) BTKC_SLASH, //0x4A (74) BTKC_L, //0x4B (75) BTKC_SEMICOLON, //0x4C (76) BTKC_P, //0x4D (77) BTKC_MINUS, //0x4E (78) BTKC_NONE, //0x4f (79) BTKC_NONE, //0x50 (80) BTKC_NONE, //0x51 (81) BTKC_APOSTROPHE, //0x52 (82) BTKC_NONE, //0x53 (83) BTKC_BRACKET_LEFT, //0x54 (84) BTKC_EQUAL, //0x55 (85) BTKC_NONE, //0x56 (86) BTKC_NONE, //0x57 (87) BTKC_CAPS_LOCK, //0x58 (88) BTKC_SHIFT_RIGHT, //0x59 (89) BTKC_RETURN, //0x5A (90) BTKC_BRACKET_RIGHT, //0x5B (91) BTKC_NONE, //0x5c (92) BTKC_BACKSLASH, //0x5D (93) BTKC_NONE, //0x5e (94) BTKC_NONE, //0x5f (95) BTKC_NONE, //0x60 (96) BTKC_NONE, //0x61 (97) BTKC_NONE, //0x62 (98) BTKC_NONE, //0x63 (99) BTKC_NONE, //0x64 (100) BTKC_NONE, //0x65 (101) BTKC_BACKSPACE, //0x66 (102) BTKC_NONE, //0x67 (103) BTKC_NONE, //0x68 (104) BTKC_KEYPAD_1, //0x69 (105) BTKC_NONE, //0x6a (106) BTKC_KEYPAD_4, //0x6B (107) BTKC_KEYPAD_7, //0x6C (108) BTKC_NONE, //0x6d (109) BTKC_NONE, //0x6e (110) BTKC_NONE, //0x6f (111) BTKC_KEYPAD_0, //0x70 (112) BTKC_KEYPAD_DECIMAL, //0x71 (113) BTKC_KEYPAD_2, //0x72 (114) BTKC_KEYPAD_5, //0x73 (115) BTKC_KEYPAD_6, //0x74 (116) BTKC_KEYPAD_8, //0x75 (117) BTKC_ESCAPE, //0x76 (118) BTKC_NUM_LOCK, //0x77 (119) BTKC_F11, //0x78 (120) BTKC_KEYPAD_ADD, //0x79 (121) BTKC_KEYPAD_3, //0x7A (122) BTKC_KEYPAD_SUBTRACT, //0x7B (123) BTKC_KEYPAD_MULTIPLY, //0x7C (124) BTKC_KEYPAD_9, //0x7D (125) BTKC_SCROLL_LOCK, //0x7E (126) BTKC_NONE, //0x7f (127) BTKC_NONE, //0x80 (128) BTKC_NONE, //0x81 (129) BTKC_NONE, //0x82 (130) BTKC_F7, //0x83 (131) BTKC_NONE, //0x84 (132) BTKC_NONE, //0x85 (133) BTKC_NONE, //0x86 (134) BTKC_NONE, //0x87 (135) BTKC_NONE, //0x88 (136) BTKC_NONE, //0x89 (137) BTKC_NONE, //0x8a (138) BTKC_NONE, //0x8b (139) BTKC_NONE, //0x8c (140) BTKC_NONE, //0x8d (141) BTKC_NONE, //0x8e (142) BTKC_NONE, //0x8f (143) BTKC_NONE, //0x90 (144) BTKC_NONE, //0x91 (145) BTKC_NONE, //0x92 (146) BTKC_NONE, //0x93 (147) BTKC_NONE, //0x94 (148) BTKC_NONE, //0x95 (149) BTKC_NONE, //0x96 (150) BTKC_NONE, //0x97 (151) BTKC_NONE, //0x98 (152) BTKC_NONE, //0x99 (153) BTKC_NONE, //0x9a (154) BTKC_NONE, //0x9b (155) BTKC_NONE, //0x9c (156) BTKC_NONE, //0x9d (157) BTKC_NONE, //0x9e (158) BTKC_NONE, //0x9f (159) BTKC_NONE, //0xa0 (160) BTKC_NONE, //0xa1 (161) BTKC_NONE, //0xa2 (162) BTKC_NONE, //0xa3 (163) BTKC_NONE, //0xa4 (164) BTKC_NONE, //0xa5 (165) BTKC_NONE, //0xa6 (166) BTKC_NONE, //0xa7 (167) BTKC_NONE, //0xa8 (168) BTKC_NONE, //0xa9 (169) BTKC_NONE, //0xaa (170) BTKC_NONE, //0xab (171) BTKC_NONE, //0xac (172) BTKC_NONE, //0xad (173) BTKC_NONE, //0xae (174) BTKC_NONE, //0xaf (175) BTKC_NONE, //0xb0 (176) BTKC_NONE, //0xb1 (177) BTKC_NONE, //0xb2 (178) BTKC_NONE, //0xb3 (179) BTKC_NONE, //0xb4 (180) BTKC_NONE, //0xb5 (181) BTKC_NONE, //0xb6 (182) BTKC_NONE, //0xb7 (183) BTKC_NONE, //0xb8 (184) BTKC_NONE, //0xb9 (185) BTKC_NONE, //0xba (186) BTKC_NONE, //0xbb (187) BTKC_NONE, //0xbc (188) BTKC_NONE, //0xbd (189) BTKC_NONE, //0xbe (190) BTKC_NONE, //0xbf (191) BTKC_NONE, //0xc0 (192) BTKC_NONE, //0xc1 (193) BTKC_NONE, //0xc2 (194) BTKC_NONE, //0xc3 (195) BTKC_NONE, //0xc4 (196) BTKC_NONE, //0xc5 (197) BTKC_NONE, //0xc6 (198) BTKC_NONE, //0xc7 (199) BTKC_NONE, //0xc8 (200) BTKC_NONE, //0xc9 (201) BTKC_NONE, //0xca (202) BTKC_NONE, //0xcb (203) BTKC_NONE, //0xcc (204) BTKC_NONE, //0xcd (205) BTKC_NONE, //0xce (206) BTKC_NONE, //0xcf (207) BTKC_NONE, //0xd0 (208) BTKC_NONE, //0xd1 (209) BTKC_NONE, //0xd2 (210) BTKC_NONE, //0xd3 (211) BTKC_NONE, //0xd4 (212) BTKC_NONE, //0xd5 (213) BTKC_NONE, //0xd6 (214) BTKC_NONE, //0xd7 (215) BTKC_NONE, //0xd8 (216) BTKC_NONE, //0xd9 (217) BTKC_NONE, //0xda (218) BTKC_NONE, //0xdb (219) BTKC_NONE, //0xdc (220) BTKC_NONE, //0xdd (221) BTKC_NONE, //0xde (222) BTKC_NONE, //0xdf (223) BTKC_NONE, //0xe0 (224) BTKC_NONE, //0xe1 (225) BTKC_NONE, //0xe2 (226) BTKC_NONE, //0xe3 (227) BTKC_NONE, //0xe4 (228) BTKC_NONE, //0xe5 (229) BTKC_NONE, //0xe6 (230) BTKC_NONE, //0xe7 (231) BTKC_NONE, //0xe8 (232) BTKC_NONE, //0xe9 (233) BTKC_NONE, //0xea (234) BTKC_NONE, //0xeb (235) BTKC_NONE, //0xec (236) BTKC_NONE, //0xed (237) BTKC_NONE, //0xee (238) BTKC_NONE, //0xef (239) BTKC_NONE, //0xf0 (240) BTKC_NONE, //0xf1 (241) BTKC_NONE, //0xf2 (242) BTKC_NONE, //0xf3 (243) BTKC_NONE, //0xf4 (244) BTKC_NONE, //0xf5 (245) BTKC_NONE, //0xf6 (246) BTKC_NONE, //0xf7 (247) BTKC_NONE, //0xf8 (248) BTKC_NONE, //0xf9 (249) BTKC_NONE, //0xfa (250) BTKC_NONE, //0xfb (251) BTKC_NONE, //0xfc (252) BTKC_NONE, //0xfd (253) BTKC_NONE //0xfe (254) }; const PROGMEM uint8_t g_extendedKeyTable[] = { BTKC_NONE, //0x00 (0) BTKC_NONE, //0x01 (1) BTKC_NONE, //0x02 (2) BTKC_NONE, //0x03 (3) BTKC_NONE, //0x04 (4) BTKC_NONE, //0x05 (5) BTKC_NONE, //0x06 (6) BTKC_NONE, //0x07 (7) BTKC_NONE, //0x08 (8) BTKC_NONE, //0x09 (9) BTKC_NONE, //0x0a (10) BTKC_NONE, //0x0b (11) BTKC_NONE, //0x0c (12) BTKC_NONE, //0x0d (13) BTKC_NONE, //0x0e (14) BTKC_NONE, //0x0f (15) BTKC_SEARCH, //0x10 (16) BTKC_ALT_RIGHT, //0x11 (17) BTKC_PRINT_SCREEN, //0x12 (18) BTKC_NONE, //0x13 (19) BTKC_CTRL_RIGHT, //0x14 (20) BTKC_PREVIOUS_TRACK, //0x15 (21) BTKC_NONE, //0x16 (22) BTKC_NONE, //0x17 (23) BTKC_BROWSER, //0x18 (24) BTKC_NONE, //0x19 (25) BTKC_NONE, //0x1a (26) BTKC_NONE, //0x1b (27) BTKC_NONE, //0x1c (28) BTKC_NONE, //0x1d (29) BTKC_NONE, //0x1e (30) BTKC_GUI_LEFT, //0x1F (31) BTKC_KEYBOARD_LAYOUT, //0x20 (32) BTKC_VOLUME_DOWN, //0x21 (33) BTKC_NONE, //0x22 (34) BTKC_MUTE, //0x23 (35) BTKC_NONE, //0x24 (36) BTKC_NONE, //0x25 (37) BTKC_NONE, //0x26 (38) BTKC_GUI_RIGHT, //0x27 (39) BTKC_STOP, //0x28 (40) BTKC_NONE, //0x29 (41) BTKC_NONE, //0x2a (42) BTKC_KEYBOARD_LAYOUT, //0x2B (43) BTKC_NONE, //0x2c (44) BTKC_NONE, //0x2d (45) BTKC_NONE, //0x2e (46) BTKC_APPLICATION, //0x2F (47) BTKC_NEXT_TRACK, //0x30 (48) BTKC_NONE, //0x31 (49) BTKC_VOLUME_UP, //0x32 (50) BTKC_NONE, //0x33 (51) BTKC_PLAY_PAUSE, //0x34 (52) BTKC_NONE, //0x35 (53) BTKC_NONE, //0x36 (54) BTKC_SYSTEM_POWER, //0x37 (55) BTKC_PREVIOUS_TRACK, //0x38 (56) BTKC_NONE, //0x39 (57) BTKC_HOMEPAGE, //0x3A (58) BTKC_STOP, //0x3B (59) BTKC_NONE, //0x3c (60) BTKC_NONE, //0x3d (61) BTKC_NONE, //0x3e (62) BTKC_SYSTEM_SLEEP, //0x3F (63) BTKC_KEYBOARD_LAYOUT, //0x40 (64) BTKC_NONE, //0x41 (65) BTKC_NONE, //0x42 (66) BTKC_NONE, //0x43 (67) BTKC_NONE, //0x44 (68) BTKC_NONE, //0x45 (69) BTKC_NONE, //0x46 (70) BTKC_NONE, //0x47 (71) BTKC_EMAIL, //0x48 (72) BTKC_NONE, //0x49 (73) BTKC_KEYPAD_DIVIDE, //0x4A (74) BTKC_NONE, //0x4b (75) BTKC_NONE, //0x4c (76) BTKC_NEXT_TRACK, //0x4D (77) BTKC_NONE, //0x4e (78) BTKC_NONE, //0x4f (79) BTKC_KEYBOARD_LAYOUT, //0x50 (80) BTKC_NONE, //0x51 (81) BTKC_NONE, //0x52 (82) BTKC_NONE, //0x53 (83) BTKC_NONE, //0x54 (84) BTKC_NONE, //0x55 (85) BTKC_NONE, //0x56 (86) BTKC_NONE, //0x57 (87) BTKC_NONE, //0x58 (88) BTKC_NONE, //0x59 (89) BTKC_KEYPAD_ENTER, //0x5A (90) BTKC_NONE, //0x5b (91) BTKC_NONE, //0x5c (92) BTKC_NONE, //0x5d (93) BTKC_SYSTEM_WAKE, //0x5E (94) BTKC_NONE, //0x5f (95) BTKC_NONE, //0x60 (96) BTKC_NONE, //0x61 (97) BTKC_NONE, //0x62 (98) BTKC_NONE, //0x63 (99) BTKC_NONE, //0x64 (100) BTKC_NONE, //0x65 (101) BTKC_NONE, //0x66 (102) BTKC_NONE, //0x67 (103) BTKC_NONE, //0x68 (104) BTKC_END, //0x69 (105) BTKC_NONE, //0x6a (106) BTKC_ARROW_LEFT, //0x6B (107) BTKC_HOME, //0x6C (108) BTKC_NONE, //0x6d (109) BTKC_NONE, //0x6e (110) BTKC_NONE, //0x6f (111) BTKC_INSERT, //0x70 (112) BTKC_DELETE, //0x71 (113) BTKC_ARROW_DOWN, //0x72 (114) BTKC_NONE, //0x73 (115) BTKC_ARROW_RIGHT, //0x74 (116) BTKC_ARROW_UP, //0x75 (117) BTKC_NONE, //0x76 (118) BTKC_NONE, //0x77 (119) BTKC_NONE, //0x78 (120) BTKC_NONE, //0x79 (121) BTKC_PAGE_DOWN, //0x7A (122) BTKC_NONE, //0x7b (123) BTKC_NONE, //0x7c (124) BTKC_PAGE_UP, //0x7D (125) BTKC_NONE, //0x7e (126) BTKC_NONE, //0x7f (127) BTKC_NONE, //0x80 (128) BTKC_NONE, //0x81 (129) BTKC_NONE, //0x82 (130) BTKC_NONE, //0x83 (131) BTKC_NONE, //0x84 (132) BTKC_NONE, //0x85 (133) BTKC_NONE, //0x86 (134) BTKC_NONE, //0x87 (135) BTKC_NONE, //0x88 (136) BTKC_NONE, //0x89 (137) BTKC_NONE, //0x8a (138) BTKC_NONE, //0x8b (139) BTKC_NONE, //0x8c (140) BTKC_NONE, //0x8d (141) BTKC_NONE, //0x8e (142) BTKC_NONE, //0x8f (143) BTKC_NONE, //0x90 (144) BTKC_NONE, //0x91 (145) BTKC_NONE, //0x92 (146) BTKC_NONE, //0x93 (147) BTKC_NONE, //0x94 (148) BTKC_NONE, //0x95 (149) BTKC_NONE, //0x96 (150) BTKC_NONE, //0x97 (151) BTKC_NONE, //0x98 (152) BTKC_NONE, //0x99 (153) BTKC_NONE, //0x9a (154) BTKC_NONE, //0x9b (155) BTKC_NONE, //0x9c (156) BTKC_NONE, //0x9d (157) BTKC_NONE, //0x9e (158) BTKC_NONE, //0x9f (159) BTKC_NONE, //0xa0 (160) BTKC_NONE, //0xa1 (161) BTKC_NONE, //0xa2 (162) BTKC_NONE, //0xa3 (163) BTKC_NONE, //0xa4 (164) BTKC_NONE, //0xa5 (165) BTKC_NONE, //0xa6 (166) BTKC_NONE, //0xa7 (167) BTKC_NONE, //0xa8 (168) BTKC_NONE, //0xa9 (169) BTKC_NONE, //0xaa (170) BTKC_NONE, //0xab (171) BTKC_NONE, //0xac (172) BTKC_NONE, //0xad (173) BTKC_NONE, //0xae (174) BTKC_NONE, //0xaf (175) BTKC_NONE, //0xb0 (176) BTKC_NONE, //0xb1 (177) BTKC_NONE, //0xb2 (178) BTKC_NONE, //0xb3 (179) BTKC_NONE, //0xb4 (180) BTKC_NONE, //0xb5 (181) BTKC_NONE, //0xb6 (182) BTKC_NONE, //0xb7 (183) BTKC_NONE, //0xb8 (184) BTKC_NONE, //0xb9 (185) BTKC_NONE, //0xba (186) BTKC_NONE, //0xbb (187) BTKC_NONE, //0xbc (188) BTKC_NONE, //0xbd (189) BTKC_NONE, //0xbe (190) BTKC_NONE, //0xbf (191) BTKC_NONE, //0xc0 (192) BTKC_NONE, //0xc1 (193) BTKC_NONE, //0xc2 (194) BTKC_NONE, //0xc3 (195) BTKC_NONE, //0xc4 (196) BTKC_NONE, //0xc5 (197) BTKC_NONE, //0xc6 (198) BTKC_NONE, //0xc7 (199) BTKC_NONE, //0xc8 (200) BTKC_NONE, //0xc9 (201) BTKC_NONE, //0xca (202) BTKC_NONE, //0xcb (203) BTKC_NONE, //0xcc (204) BTKC_NONE, //0xcd (205) BTKC_NONE, //0xce (206) BTKC_NONE, //0xcf (207) BTKC_NONE, //0xd0 (208) BTKC_NONE, //0xd1 (209) BTKC_NONE, //0xd2 (210) BTKC_NONE, //0xd3 (211) BTKC_NONE, //0xd4 (212) BTKC_NONE, //0xd5 (213) BTKC_NONE, //0xd6 (214) BTKC_NONE, //0xd7 (215) BTKC_NONE, //0xd8 (216) BTKC_NONE, //0xd9 (217) BTKC_NONE, //0xda (218) BTKC_NONE, //0xdb (219) BTKC_NONE, //0xdc (220) BTKC_NONE, //0xdd (221) BTKC_NONE, //0xde (222) BTKC_NONE, //0xdf (223) BTKC_NONE, //0xe0 (224) BTKC_NONE, //0xe1 (225) BTKC_NONE, //0xe2 (226) BTKC_NONE, //0xe3 (227) BTKC_NONE, //0xe4 (228) BTKC_NONE, //0xe5 (229) BTKC_NONE, //0xe6 (230) BTKC_NONE, //0xe7 (231) BTKC_NONE, //0xe8 (232) BTKC_NONE, //0xe9 (233) BTKC_NONE, //0xea (234) BTKC_NONE, //0xeb (235) BTKC_NONE, //0xec (236) BTKC_NONE, //0xed (237) BTKC_NONE, //0xee (238) BTKC_NONE, //0xef (239) BTKC_NONE, //0xf0 (240) BTKC_NONE, //0xf1 (241) BTKC_NONE, //0xf2 (242) BTKC_NONE, //0xf3 (243) BTKC_NONE, //0xf4 (244) BTKC_NONE, //0xf5 (245) BTKC_NONE, //0xf6 (246) BTKC_NONE, //0xf7 (247) BTKC_NONE, //0xf8 (248) BTKC_NONE, //0xf9 (249) BTKC_NONE, //0xfa (250) BTKC_NONE, //0xfb (251) BTKC_NONE, //0xfc (252) BTKC_NONE, //0xfd (253) BTKC_NONE //0xfe (254) ------------- |
[top] | |
DAVID | Posted: 10 Feb 2018, 11:36 PM |
only problem with this is that is recognized in the bios and not when booting up the system ------------- |
[top] | |
DAVID | Posted: 11 Feb 2018, 10:44 AM |
for it to be capable to boot in windows i need first to connect a ps2 keyboard or use a ps2 to usb adapter Last edit by DAVID at 16 Feb 2018, 03:19 AM ------------- |
[top] | |
